Standard trans fluid???
what is year and make of vehicle? auto or standard tranny?0
I ALWAYS USE LUCAS FULID FOR THE TRANS (STANDARD) AND REAR END I USE THE ENGINE OIL ADDITIVE IT'S BEEN IN MY 50 PACEMAKER CV FOR OVER 10 YEARS AND NEVER HAD A BIT OF TROUBLE IT IS A BIT THICKER THAN 80/ 90/120 IT REALLY STICKS TO THE GEAR FACE
Thanks for the link Kdancy, it's a 53 3 speed manual with OD sorry I didn't include that. How much does it take? Quarts?0
Should be a dual lever BW T86 --
manual says double lever transmission is 2.25 lbs
double lever trans with OD is 3.25 lbs
The conversion is very close to 1lb= 1pint
yes it is a dual ever t86. Is that pints or quarts. I can't believe it takes less than a quart to fill it. =D>0
I also don't know how that little guy got into my post. This is my first time posting from my phone0
All done. Yes pounds equal pints. Thanks for all the help0
i thought the "pints a pound, the world around" thing was about ale not oil!
