looking for a double groove water pump pulley
Chris Smith
I am looking for a hudson double groove water pump pulley from a hornet with power steering.
I have one I can sell--I paid 200 for it--but bought a complete PS setup - so now I have 2.0
Quadster-You paid $200 for the WATER PUMP pulley, or the harmonic balancer? $200 for the former is pretty high, but for the latter is what they are currently going for.0
If your only looking for a double groove Water Pump Pully Ive found them plentiful from other motors at Swap Meets having the same 'pilot hole' only needing to file outboard slightly the 4 mounting holes....
With all due respect for those of you long time Hudson owners---One can spend a lot of weekends going to swap meets searching for hard to find parts.Or you can spend a little more for a nicely bead blasted and painted part and spend the swap meet time enjoying your Hudson by working on it or better yet driving it.0
To add to Ol' Racer's note, be aware that you can, with a decent hydraulic press, slide the pulley "mount plate" in or out on the shaft a bit, to accommodate small differences in the depth of miscellaneous pulleys. This is especially so if you have one of the longer shaft pumps used from '54 on.0
If you are moving it "in", be sure to support it by the opposite end of the shaft, not the housing or impeller.
F0
