Jet gas tank sending unit.
Nevada Hudson
Boiled out the gas tank on the Jet, ready to install in car. Sending unit just twists on hole, does not bolt on like stepdown. Is there a gasket for this or can I just put some Permatex blue seal on the outside to seal it?
Cheers!
Cheers!
YES THERE IS A O RING THAT GOES UNDER THE SENDING UNIT0
Where can I find the O ring?0
I HAVE THE COMPLEET UNIT WITH THE ORING I'LL LOOK AND SEE IF I HAVE ONE0
I DO NOT HAVE A LOOSE ONE BUTBOB DRAKE FORD HAS THE O RING YOU NEED $2.00 + SHIPPING0
Will try that. Thanks, Paul!0
