1947 pickup wiring diagram
The 1947 Owner Manual has a very nice copy included. This can be enlarged for easier viewing/use.I took mine to Office Max , had them enlarge it and laminate in heavy plastic. Very easy to use.If you don' have one, they appear quite often for sale on e-bay.Good Luck,"Ric"0
You've tried the H-E-T website, under "Library"? I'd guess it's in the '46-7 shop manual, though I haven't checked. Of course you would have to be registered to use the library, but if you're an H-E-T Club member you can do so and get full privileges. If not, you can still register as a limited registration but I'm not sure if use of the on line library is included.
There is a very legible diagram on Pg 114-115 of the 1942-1947 Mechanical Procedure Manual. Truck diagram is the same as the car.0
Thanks I never saw it on the back off the fold out on the cover.0
