Vapor Lock ......Help
harry54
harry54 Senior Contributor
My 53 Hornet with twin H always seems to vapor Lock when the Temp goes over 70 . Why does this happen ? What did Hudson do to remedy this problem? I know that people use back up electric fuel pumps but that is a bandaid. These are my questions .
1. Why does this condition happen ?
2. What did Hudson dealers do to fix the problem back in the day ?
3. Does this only happen on Twin H cars ?
4. WHat if you back up electric fuel pump fails ?
THx....
  • Harry I'll let the others tell you about the vapor lock story. Here's how I got rid of mine. First,disconnect the metal fuel line going to the carb from the fuel pump. Replace it with a rubber fuel line and route it away from the engine and manifold. There will be no percolation of gas by the main heat sources and your vapor locking problem will be gone. Forget tha clothes pins on the fuel line stuff. That really dosen act like a real heat sink is supposed to anyway. Besides it looks like you just hung out the wash.. BTW vapor lock occurs on cars with or without twin H.
  • harry54
    THnks Hudzilla, what about insulatiting the Fuel line with some kind of insulation ?
  • 53jetman
    53jetman Senior Contributor
    The vaporlock problem is a modern problem we didn't have "back in the day".
    This situation is brought about by modern fuels more than anything else. Most of us have eliminated vaporlock by either using the above suggestion, and/or installing an electric fuel pump back by the tank. I personally have completely done away with my mechanical fuel pump and the Jet runs on a Carter electric rotory pump exclusively.
    Jerry
    53jetman
  • SamJ
    SamJ Senior Contributor
    Gasoline is more volatile than it used to be and evaporates more easily. One solution for older cars is to put Marvel Mystery Oil or diesel fuel in your gasoline. 8 oz per tankful. :cool:
  • Jon B
    Jon B Administrator
    I had vapor lock in my '37 engine many years ago. So, I wrapped the metal fuel line (fuel pump to carb) AND the exhaust pipe with asbestos (!). This helped quite a lot! I also installed an electric fuel pump as my primary fuel pump. No more vapor lock.
    Maybe 20 years ago I decided to tempt fate, and went back to the mechanical fuel pump. As the years passed, the asbestos-wrapped fuel line and the asbestos-wrapped exhaust pipes were replaced with newer ones (not wrapped) and -- guess what? -- still, no more vapor lock!
    Another possibility: is your exhaust damper stuck open (so you are getting hot exhaust gasses heating the carb)? Check for smooth operation and note its position (open versus closed) when you first start the car, and when it warms up, to make sure it's working properly.
  • harry54
    WHat does the Marvel Mystery oil do ?
  • Park_W
    Park_W Senior Contributor
    I had this problem on my '51 C8 a few years ago (Technically I guess it's not vapor lock, which term I understand to mean the fuel turning to vapor on the suction side of the fuel pump, not the pressure side). Whatever you call it, in my case I noted the engine compartment was awfully warm, and figured the best way to deal with that was reduce the temp of that big ol' engine block. I put a modern style radiator core in it, with a 160 thermostat, and the problem disappeared forever.
  • I did as Hudzilla said, Ran a rubber line to the inner fender liner the thru an inline filter then back to the carb. This keeps the heat away from the fuel line so that the gas does not flash into vapor.... No vapor lock.
    Actually Park is correct that the problem is on the pressure side of the pump and not the vacumn side where a true vapor lock would happen. The flash point of modern gasolines is quite a bit lower than the gas of days gone by. That is why we see so much more of a vapor lock problem. Since the early seventies, if I remember correctly.
    I have heard of putting Marvel Mystery Oil in the gas but don't know how much it takes. The idea being that the MMO will change the flash point of the gas, making it slightly higher, thus less prone to vaporizing in the fuel line.
    Just some things I have heard and formed opinions on
    Bob
  • How about using Walt Mordenti's fuel return line mod?
  • hornet53
    hornet53 Senior Contributor
    I had a vapor lock problem for a while, I routed my fuel line to the fender also, but the main problem was the heat shields under the carbs. They were turned backwards for some reason. Make sure they are facing forward. Solved the problem for my 53.
  • drdoug
    drdoug Senior Contributor
    Vapor lock??? This is such a good subject!! I feel there are several reasons for this concern,many of which are described and talked about already.I also have messed with the growing concerns of engine vapor lock,especially on Twin-H equipped vehicles.You discover the vapor lock concerns after the engine is completely assembled and running,driving.As I said,the descriptions listed in this thread are all solutions to this concern,BUT,look at the manifold before installing it onto the engine.This is ESPECIALLY true with the Twin-H.If you separate the manifolds-exh.int,while off the engine,you will see 3 & 3,plugs in the bottom of the intake manifold for each carb.These must be removed,and all the heavy carbon cleaned out.If you look at the design,it is a trap for carbon.These cavitys go back under the carb areas,as they were designed to do for constant heat at the base of the carbs.,fill almost completely with carbon,and while driving down the interstate at cruise speed,the carbon begins to glow.Picture you charcoal grill with glowing ambers?.This is what I have found takes place in the inside of the intake manifold exhaust passage.Once this carbon is glowing,it will not cool off until the engine has set and completely cooled off.Picture taking your carbs and putting them over a fire and think there would be any fuel left in them??Also in just an overnite cool off period,the engine heat has boiled all the fuel out of the carbs and then creates a long crank time to fire the next day??.When removing these plugs,be extra careful.Don't drive them in,drill a hole in the plugs and use a dent puller to take them out.Once you have them removed,you will see the carbon build up.Not all manifolds will be real bad,but most are.I think the build-up depends on the miles,and the condition of whatever the manifold was on.I have removed these plugs and it is solid carbon and it takes awhile to remove it all.I also suggest if you manifold is full of carbon,remove what you can with a pick and screw driver,then take it somewhere to have it boiled or tanked until it is clean.Also where RE-installing these plugs,make sure you have the correct size,and don't hit them too hard to make them swell.The carbon has eat up some of the seat these go in,and pounding on them to hard will break the seat off into the manifold,and will require some welding to repair.Remember,just sticking the air hose in the passage in the center of the manifold will not clean the carbon from beneath the carb "Pods".it might seem clear,but they usually are NOT.I hope this other bit of info helps these problems of fuel vapor locking.
  • Park_W
    I would think the "return flow" mod would help the situation. Keeping the fuel moving, in the lines near the heat source, would certainly reduce the chances of its absobing enough heat to vaporize.
  • SamJ
    Don't forget...altitude can be the culprit in vapor lock. The less ambient air pressure, the faster fuel will vaporize. Couple that with engine heat increase on steep grades...not good. Usually happens while your car is parked in the restaurant at the top of the hill. :cool:
  • Jon B
    Jon B Administrator
    Oh, and here's another simple suggestion: add two or three more fiber gaskets between the carb and the manifold, to elevate it off the hot manifold. On my '37 I have:
    4 gaskets
    1 metal heat shield
    4 gaskets
    This was not what was done originally (they didn't even have a heat shield so far as I know) but, given the volatility of today's gasolines, it will help.
  • duncan
    duncan Expert Adviser
    put 1/2 quart of 2 cycle engine oil in full tank of gas works awsome
  • I had the problem ten years ago. The engine ran hot so found a 6 blade fan and I think I put in a 160 but could be a 180 degree. Mine runs around 185 to 200 depending on outside temp and if moving or not. I had a electric pump but its qui9ck working but rebuilt a single action a couple years ago and no problems. I do have the fome plumbing instuation of the line under the hood. Jerry jbmiller782@comcast.net
  • Uncle Josh
    Uncle Josh Senior Contributor
    My 36 Terraplane was vaporlocking, and I found the fuel-pump screen plugged, thus drawing a high vacuum on the gas which turned it to vapor, which or course, the pump is not designed to handle. No problems since cleaning the screen.
  • nick s
    nick s Senior Contributor
    I too have had pseudo-vaporlock issues. Had a line sucking air and also had an inline filter element actually collapse. be sure to check out your entire fuel system, including the pick-up tube, for leaks and obstructions.
  • kamzack
    kamzack Senior Contributor
    Hey All,
    This interaction is why I like Hudsons and Hudson people. What a great exchange of info.
    This ametuar, self taught, shade tree mechanic solved vapor lock on a V8 Stude with the Mopar fuel filter and a line back to tank. allows foamed fuel a path of escape. As mentioned, modern gas has a much lower boiling point, so any measure one can take to resolve is good. I've also used an electric fan instead of water pump fan to move hot air from domed engine compartment at speeds below 30mph
    I prevented vapor-lock on a 262 by using headers before installing in a Commodore. Separating heat of exhaust from intake works very well. This is certainly not a contradictory solution, but another alternative. Wish someone would come up with a set of headers for 254 I'm rebuilding.
    Thanks for letting me share,
    Kim
  • PAULARGETYPE
    PAULARGETYPE Senior Contributor
    First The Return Line System Was Stock On All 1957 Hudsons With That Said On My 50 Pacemaker With 308 And Twin H I Installed A 6 Volt Elect.fuel Pump Back By The Fuel Tank Problem Solved !!!
    I Don't Care For The Rubber Hose Fix If That Line Springs A Leak Or The Clamp Comes Loose Oh What A Fire And We Don't Need That Happening To Any Hudsons
    Hudsonly
    Paulargetype
  • Geoff
    Geoff Senior Contributor
    One section of Murphy's Law states - "In an over-all evaluation, all errors will be cumulative" - In other words the more stuff you add on to improve reliability, the less reliable the system will become. Ditch the inline filters. One of our club members here had incessant troubles with the vacuum tank on his '26 Essex. cursed it all the time, and eventually threw it away and installed an electric pump, and still had problems, due to his in-line filter allowing air to be sucked in. Paradox is that his vacuum tank already had built-in filters. Another guy figured it was a waste of time draining out the bottom of the vacuum tank regularly, so just installed an in-line filter between the tank and the carb. Result, eventually the gunk built up in the bottom of the tank, and blocked the tap off! "If it ain't broke - don't fix it."
  • Vapor lock is always in the fuel pump. The pump must move gas. The next time you get vapor locked, take a bottle of water and pour it over the pump and your car will start right up. Hot gas lines or manifold will boil the gas in the carb and that floods the engine making it very hard to start. That is why I put my return system on my car and can drive it in 105 degree weather, stop for lunch, get back in and start right up and on my way.
  • dave s
    dave s Senior Contributor, Moderator
    Better than the water is keep an aerosol can of the spray cleaner that is used for cleaning dust from computer keyboards and such. Spray fuel pump and instant freeze!:)
  • walt's garage-53 wrote:
    ......That is why I put my return system on my car.......
    Can this be done using the OEM Carter WA-1 749S carb?
  • Hey Walt,
    How about posting more info on your return line mod? The weather is getting warmer and there seems to be lots of interest in eliminating vapor lock.
  • It will take a lot of space here to write the full mod. If anyone is interested just send Walt a large self addressed stamped envelope and I will send you a copy of the write up. It's the sure fix for vapor lock, any year Hudson. We now install this system on all old cars that come into the shop where I do all the engine rebuilding and carburetor rebuilds. Cadillac's of the 40's are our biggest customers. Just like what was mentioned earlier, it's our gas of today that is causing all the problems.
  • It doesn't matter which carb you use or fuel pump. The idea is to keep cool gas in the fuel pump so as not to boil
