Temporary loss of electrons?
Well, we had some good steady rains to wash the winter salt off the roads so I figured it was the right time to get the Hornet out of 3-month storage and go for a nice long drive. I checked the fluids, sprayed a short blast of ether into the carbs, hooked up the battery (6.15 V, a little on the weak side but probably enough to ignite the ether), let the electric fuel pump do its thing for about 10 seconds, pumped the pedal until I heard gasoline squirting into the intake, and then engaged the starter. It cranked for about one second and then nothing. Kind of sounded like the Bendix gear got stuck so I figured I would loosen the starter bolts to free it up and try again. Then I noticed no idiot lights, and no courtesy light when I opened the door to get out. Total loss of electrons in the car. I spent a few moments in silent wonder and happened to notice little puddles of water on the concrete floor under the car. Dew drops were hanging off the frame in great abundance probably because the garage floor was still pretty cold while the humid air that moved over the past few days was quite warm (up near 80 degrees). Anyways, I fiddled with the battery cables, got back in the car and noticed I got my courtesy lights and idiot lights back. Encouraged by my dumb luck, I hit the starter, the engine roared to life, and I was out for a spin. I don't know what happened here but figure I got a short of some sort from the starter circuit to the wet frame. With little electrical resistance through the short, this must have tripped the circuit breaker causing my electrons to disappear. Maybe as I stood around looking at all the dew drops, the circuit breaker cooled off and I was given a second chance at starting the car. Can I blame this one on the weather or am I missing something of a more serious nature? Thanks for your help and best wishes! ArtS
I've had similar things happen to me, and it's usually because the connection between the battery cable and the battery terminal (or the ground strap and terminal) isn't the best. Have you tried removing the cable and strap, and cleaning everything off? In fact, are all terminals of all straps and cables, making good connections / grounds at their various locations?0
Jon B wrote:I've had similar things happen to me, and it's usually because the connection between the battery cable and the battery terminal (or the ground strap and terminal) isn't the best. Have you tried removing the cable and strap, and cleaning everything off? In fact, are all terminals of all straps and cables, making good connections / grounds at their various locations?
You make a good point, Jon, as I really haven't given the ground strap a good inspection. Seems OK at the battery support but I should take a better look at the motor mount connection. Thanks for the tip.0 -
For the protection of your Hudson the garage needs more ventilation to keep water from the car. This may be accomplished thru the use of a fan or a dehumidifier.
I keep my 30x40 dry using a <$100 dehumidifier
save the dehumidifier water for car batteries, it pure with no lime, chlorine ect.
29 Vic0 -
29 Vic wrote:For the protection of your Hudson the garage needs more ventilation to keep water from the car. This may be accomplished thru the use of a fan or a dehumidifier.
29 Vic
That's a good idea for next year's winter-to-spring transition. I have a large box fan that I can direct at the floor under the car. The floor is now warmed up and all is dry. We had an unusual weather pattern this Jan-Mar. Never saw this before but all our garage floors were affected the same way. Also, I was thinking of putting down plywood sheets under the car.0 -
All those connections need to be 'Brite n'tite' boys!0
- 611 Vehicles
