Driveshaft Bearing
Hudsonrules
Its not a bad idea and shouldnt be too difficult. I spent a life time in Beverage Maintenance where all the Trucks had a couple 'carrier bearings' to correct the driveline angles resulting from narrowed & dropped frames. The bearings never required lubrication and seldom failed.0 -
The Driveshaft Bearing is a sealed bearing and requires no maintenance.
If you want to replace the bearing, here are the part numbers for the bearings.
'48-'52 All Exc Pacemaker and Wasp use #88506
'50-'52 Pacemaker and Wasp use #88107
'53-'54 All Exc Jet use #88107
I am not totally sure about the above infomation. So here are the dimensions of the bearings. You can measure yours and pick the right one.
#88506
ID 1.1811 inchs
OD 2.4409
Width 0.9449 inchs
#88107
ID 1.3780 inchs
OD 2.8346
Width 0.9843 inchs0 -
mars55 wrote:The Driveshaft Bearing is a sealed bearing and requires no maintenance.
#88506
ID 1.1811 inchs
OD 2.4409
Width 0.9449 inchs
#88107
ID 1.3780 inchs
OD 2.8346
Width 0.9843 inchs
I put a new BCA 88107 bearing in my 50 Pacemaker so I know that to be correct. Richie.0 -
And It's The Same Bearing That Is Used In A 1972 Chevy 1/2 Ton Pick Up Truck Your Local Parts Store Has It On The Shelf Just Waiting For You To Ask For It But Don't Ask For A Hudson Bearing They Don't Have It Listed That Way0
PAULARGETYPE wrote:And It's The Same Bearing That Is Used In A 1972 Chevy 1/2 Ton Pick Up Truck Your Local Parts Store Has It On The Shelf Just Waiting For You To Ask For It But Don't Ask For A Hudson Bearing They Don't Have It Listed That Way
Uh oh! This makes me remember a story my brother once told me about the time he tried to remove one these bearings from his '78 chev. pickup. Something about securing the shaft in a giant vise, heating it until it was red hot and having a 300 lb. garage guy named "phatboy" beat on it with a sledge.....0 -
Hudsonrules wrote:
Take your drive shaft off and don't let the needles fall out of their cups. Mark the shafts so when you reinstall the 2 together they are back in balance. Remove the large nut and the bearing will slide off and slide the new one on. Reinstall the shafts together using your marks and you are back in business. Walt.
I saw a write up on repacking the drive line bearing on the step down. It made me think, I have put thousands of miles on various Hudsons and never gave that a thought. Now, after sixty or so years, I will attemt to remove and repack the bearing, or is it better to replace the bearing. I seem to recal that some Ford or Chevy trucks used the same bearing. Will I be attempting a bigger job than expected? Thanks Arnie0
- 588 "How To" - Skills, mechanical and other wise
