Ford headlight rings on a hudson
I've seen them on a couple. Don't know about "Work".
probably drill some holes.
The headlight rings on hudson is fastened with a "hook" on the top and one screw in the bottom. I don't know how the ford is designed, but i don't think there should be any bigger trouble.0
My 27 Ford "T" has 'Essex' headlight lenses in the original Ford rings. I'll bet the Ford rings can work on your Hudson.
R/Roger.0
