Hudson 232 thermostat
OEM style or modern using the modified housing?0
Contact Walt Mordenti at hetwaltmordenti@aol.com drop the het, he makes a kit that helps cool the radiator and uses a modern thermostat, 160 degrees, and have sold a few in your area. Walt.0
PM500 - I will look at either option. Original is fine if there are no issues with using these. Are they available?
Walt - have sent you an email0 -
If you buy a NOS bellows type one shake it and if it sounds like it has liquid inside it should still be good. Also that on type some require a top gasket to fit right and some dont. Depends on who made the thermostat,
Roger0 -
Mopar thermostats from the 60's-70's fit if you want to go that route. But you need to plug the bypass if you have a bypass type and drill a small hole in the plug,
Roger0 -
Thanks for that Roger
Here are 3 different part numbers for a modern 160 degree thermostat. Stant #13076, Stant #29706 and Carquest #30236. I know for sure that the Carquest part will work, because that is what I'm using in my Pacemaker. You will need to block the bypass and drill a small hole in whatever you use for the bypass block as Roger said.0
The last time I bought a new one at the part store the coolest they had was 160 . would have liked cooler one but oh well,
Roger0
- 182 The Flathead Forum
