Hub puller for brake drum removal
keithfullmeryahoocom
Anybody know a source for the required puller for removing the rear brake drums on a '50 Commodore? Rent, borrow, buy? These guys are STUCK!
You might call a tool rental company, especially one that's been around awhile. They might have one. Otherwise, it might not be a bad idea to invest in one, since you may need it again. This drum will give you just as much trouble the second time around.
On Ebay I see a couple used ones whose bids are now in the $30's, and there are new ones ranging from $60 up to the $90's.0 -
Thanks Jon. Don't know why I didn't think of that. Lots of them on there. I opted for an old Snap on over the ones that just had a "sketch" instead of a real picture. Looks like it has been around the horn a few times, probably yanked several drums. keith0
Ken, do you still sell the original brake parts? (I am anticipating that I will finally succeed in the rear brake drum removal.) Lol.
look at ebay for a "hub puller" like this one ( not mine )
https://www.ebay.com/itm/TruePower-20-2029-Universal-Hub-Puller/202195429223?hash=item2f13c96767:g:BnkAAOSwlv9aYqbS
Where are you located? If you are kinda close to me I have one you could borrow. (44833)0
Thanks, bluenash, for the generous offer. I went ahead and bought one that I saw on ebay. Drums are still there and waiting for it to show up...k0
The structure of the 2 piece design of the Hudson (and others) brake drum needs those 5 rivets to give the drum rigidity, they were put there to do more than just keep the brake components together while the car went down the assembly line.
Car makers and component suppliers have always been looking for ways to shave a few cents off their costs. If the brake designers/engineers of the day thought it was OK to punch just 3 rivet holes in the hub and drum rather than 5 and install just 3 rivets (2 standard rivets and 1 peg rivet) that's what would have happened.
Then downgrading the downgrade that never happened from hot rivets to countersunk screws?
I'll stick to 5 rivets and using to a drum puller every now and then.0 -
syddthekidd said:I know someone is going to scream "NOW YOUR DRUM ISN'T CENTERED"......which is why you do the rivets one at a time. Works like a charm.
So what would one do if a previous owner drilled out all the rivets (and left them out) to do the brake work? I have not yet driven the car so I do not how the brakes will feel driving but I have a nice pedal feel sitting still. As a side note the P/O worked at a tire and brake shop and put in all new shoes, turned the drums, new rubber hoses, wheel and master cyl.
I have an extra one of these if anyone is interested in adding it to your tool collection.0
50C8DAN
Please PM me. How much for the hub puller?
Thank you.
Thanks syddthekid. How did you use the press in studs? Did you drill out the hub to remove the threads or is there a wheel stud that threads in from the back?syddthekidd said:RG53Hornet. I think if I ever ran into this (which I don't think will ever happen) I'd install wheel studs as I have done and I wouldn't worry about it. There is a small boss on the hub to center the drum and once you pull the wheel nuts up tight you have the same exact assembly as almost every other automobile running around with rear drum brakes. The wheel cylinder will push the brakes out until they contact the drum....the drum is the stop....it'll get there. I assume you've seen this situation. If so, someone must not have had a hub puller or didn't know any other way to get to the brakes. If you install wheel studs from the back side of the hub you no longer need the locating pin anyway....you have 5 locating pins.
Robert
Good info, thank you very much!syddthekidd said:RG53Hornet. At the risk of drawing more flack from the it'll never work crowd I actually used 7/16 studs and the knurling bit right into the 1/2" threads in the hub. I've made two trips to California and back from Ohio in my truck and the wheels didn't fly off. The second trip was in the 70mph range as my truck has a 262 and I installed a dana diff with 3.54 gears before driving to San Diego last year. You can't beat this set up for brake access and it saves the threads on the end of the axle. I'm sure in my lifetime I'll never have the hubs off again. When I installed the diff the gears, bearing, seals, etc were all new so I'm set for life.....and when I want to change the brakes, no problem. Be careful when buying the studs, the do come with different knurl sizes. If you have the hub off take it to a local parts store or take a set of calipers and measure the inside threaded portion and get on summit racing and look for studs. They usually list the knurl diameter. Get it a bit bigger than the inside dia. on the threads so it can get a bite.
- 118 Hudson 1916 - 1929
