Kleinig Hudson Eight Head
Spencer Yarrow
Here are a couple of pictures of my garage mantle piece. This is a genuine Frank Kleinig design - manufactured head to suit Hudson Eights. Kleinig used these heads in his early racing days whilst racing his Hudson special. Only a couple of these heads survive today. NOT FOR SALE:)
Spencer,
I am very interested is seeing a photo of the other side of Kleinig's head--the shape of the combustion chamber and the spark plug placement.
Thanks for posting these. I am well aware of the Kleinig Special and have copied some details of his Hudson 8 oiling modifications to the stock splasher system.
Cheers,
Ivan0 -
About time you cleaned that floor Spencer, should be spotless so I could eat my dinner on it.lOL.
Just a side issue, Mavis Gibson ( Clive's wife of 64 years) passed away Dec 1st 2008, she will be sadly missed as are any of our Hudson family who pass away.0 -
Ivan, tell us more about these oiling modifications please....0
My Railton has a girotor style oil pump (actually from an old Mini-Cooper) mounted on the front cover and driven by the nose of the cam. It draws out of the standard Hudson pick up and pan and pressures oil through a remote full flow oil filter into an oil cooler mounted under the radiator and back into the motor from a log manifold parallel to the oil pan that has nine 3/16" tubes feeding through fittings in the side of the sump at each rod position and into the timing gear case. The oil pan is post war deeper style and the dipper tray is late step down configuration, that is high oil level. The little tubes enter through the wall of the sump and go into and are stayed in holes drilled in the dipper tray pieces that were designed to "catch" the oil slung up by the rod splashing through the puddle at bottom dead center. The whole point of this is to insure oil supply at each rod position all the time, to filter, and to cool the oil which is heated tremendously by the splashing at high revs regardless of cornering forces created sliding around the race track. I generally have observed the oil and water temps to run about the same (190 degrees) at the end of a 1/2 hour sprint.
This was brought on by a rod bearing failure the first time I raced the car, my reading of the history books about Hudson's rod bearing failures with the then new 8 cylinder at Indianapolis, and Australian Frank Kleinigs very fast Hudson 8 powered racer which had similar modifications.
Hope that's sort of clear--ask if not.
Ivan0 -
That sounds interesting do you have any pics of that setup?0
Attached are four images--I'm afraid they are too small. If you can't see what you want . let me know and I'll try to make them larger.
Ivan0
- 182 The Flathead Forum
