Stud remaoval
May seem like a beginner question, but looking for suggestions to remove studs from my 254. I tried a post a little earlier but didn't take. If this a duplicate, forgive me. Block has been at the machine shop for nearly 3 years. I wanna go to Detroit this summer in my Hudson as I'm less than 100 miles from. he's tried the blue axe, I soaked with pnentrating oil fir weeks before it went to machine shop.
Thanks in advance,
Kim
Thanks in advance,
Kim
There are many stud removal tools available. from Harbor Freight and J.C. Whitney, Sears, NAPA, Auto Zone to name a few, But I am assuming that you are talking about a stud that is broken off and is too short to get a tool on. I broke off three headbolts in my 54 308 engine. I had to drill out the bolt center then use an easy-out and a lot of PB Blaster over a period of 6 months. Of course I wasn't in any great hurry.
Bob0 -
Find a good welder. even if the stud is broken off below the surface, he can build up that broken stud ,weld a washer and a screw to it. It will screw right out. Probably take about five to ten minutes for each stud. It can't be someone who will give it a shot or thinks they can do it. Jim0
One of the prior posts mentioned using an easy-out for this case. Well, when I was younger I tried this on some frozen bolts and let me tell you, it was one of my worser ideas. I ended up with a broken off hardened insert that was then impossible to drill out.
One of the other posts mention EDM. What is this?0 -
i have done the welding several times, but never on a rare engine. i think the heat from the weld really helps the most in freeing the bolt. it seems like they always turn pretty easy then after they cool down. you can cut a heat shield so you don't get on the hole boss. good luck0
i would be pretty cautious about he easy out too. on a rusted in frozen bolt, would hate to take the chance myself.0
41 hud wrote:Find a good welder. even if the stud is broken off below the surface, he can build up that broken stud ,weld a washer and a screw to it. It will screw right out. Probably take about five to ten minutes for each stud. It can't be someone who will give it a shot or thinks they can do it. Jim
This is the the right approach to numerous studs that are broken. If it is just 1 or 2 ,then get out the drill and start drilling in steps. If there are several,the welding technic described is a common practice and also uses a special rod. If you go to the local welding supply,tell them what you are doing and what you want to do,they will sell you this special rod. place a nut on top of the broken stud and weld it,turn it out. This does work,been there ,done that. If only I could have come up with such a special rod!!!
On a earlier note,removal of these studs is done with proper tools. I have personally taken hundreds of studs out,and some of them the very toughest to get out. It all starts with good tools. Snap-on Tools sells some of the best extractors and stud removers. I think the # is A-161 for their stud remover that really does work GREAT! These come in 2 different sizes,this one accepts up to 1/2 studs. It does not turn like some stud removers with the 2 different size holes and an eccentric cam. These have 3 jaws and turn in the center. Hope this helps0
